Reply
Re: 15/M plan
So far, I've been pleased to note that 888/800 numbers that I call aren't subtracted from the limited number of minutes in this plan.
Note that calls are generally billed by the minute.
As noted, there is an add-on that you can apply to your account through the Self-Serve option - $5 for 500 minutes.
Re: 15/M plan
The $15prepaid plan is good for 30 days, not a month. If you used up your mins, data each month you will not be able to continue unless you purchase a add-on in that 30day cycle.  People still can call you if your 100 mins are used up. These add-ons do not expire until they are used up. $5 buys 500 Canada wide outgoing mins.
