11-24-2022 03:02 PM - last edited on 11-24-2022 03:47 PM by computergeek541
Good Morning,
I am unable to log into our son's account. he has forgotten his password. Can we change the e-mail linked to our home e-mail xxxxxxxxxxxxx.
We would like to change his plan, and cannot do anything at this point, due to not being able to access his account.
Please help.
11-24-2022 04:35 PM
@Bridget21 wrote:"he has forgotten his password"
First reset password at log in page. It it doesn't work, then you can send private message to customer service to ask change email:
11-24-2022 03:08 PM - last edited on 11-24-2022 03:49 PM by computergeek541
Please remove personal info from public forum!!!!
Contact agent to update your email.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
11-24-2022 03:04 PM - last edited on 11-24-2022 03:49 PM by computergeek541
HI @Bridget21 don't put your personal info on the forum, remove it. You can go back, click down arrow and edit your post to remove
To change email used, only CS agent can help, please open them ticket:
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
