why my phone download message failed?
Pingzh
TXT message is ok, but it is problem with sending or receiving a image or a picture  message.
8 REPLIES 8
@Pingzh   Did you get it working?  If not, see this thread also about a OnePlus phone
https://productioncommunity.publicmobile.ca/t5/Get-Support/Cannot-send-or-receive-mms/td-p/1169823
@Pingzh
to Reset all networks
Navigate: Settings > System > Reset options.
Tap Reset Wi-Fi, mobile & Bluetooth.
Review the info then tap Reset settings.
To confirm, review the info then tap Reset settings.
Pingzh
mY PHONE IS ONE PLUS 9, ANDROIL 12
Pingzh
COULD U SHOW ME HOW TO RESET?
@Pingzh   You need data, not wifi, for MMS messages.  Is your phone android or iPhone?
Pingzh
wifi is on too
Pingzh
data is on
@Pingzh MMS needs Mobile data to be on, do you have it on?
if data on and still fails, try click Reset all networks
