06-03-2018 06:55 PM - edited 01-04-2022 06:06 PM
little confused as i have a $10 plan and my dad has a $20 plan but neither of us got a text about putting our credit cards in auto-renew
06-04-2018 01:45 PM
i am on the 30 day and getting charge 70 for it that whay to much here what they charge me when i told put 110 that dont look right
| Jun 3, 2018 | System issue/ Problème du système | $10.00 | $30.00 | |
| Jun 3, 2018 | 6GB + 500MB BONUS at 3G Speed/6Go + 500Mo EN PRIME à la vitesse 3G | $40.00 | $20.00 | |
| Jun 3, 2018 | Unlimited Talk to Canada and the US/Appels illimités vers le Canada at les É.-U. | $30.00 | $60.00 | |
| Jun 3, 2018 | Unlimited International Text/Messagerie texte à l'International | $10.00 | $90.00 | |
| Jun 3, 2018 | 30-day pass/Passe de 30 jours | $10.00 | $100.00 | |
| Jun 3, 2018 | 3 Choices with Talk to Canada & US/3 Choix avec les appels nationaux et aux É.-U. | $35.00 | $110.00 | |
| Jun 3, 2018 | System issue/ Problème du système | $75.00 | $75.00
06-04-2018 10:27 AM
As mentioned, all plans are eligiable for the $2 autopay, but unlike other one time promotions where you get a text, you will not recieve a text about the auto-pay. It just appears in your account.
06-04-2018 12:53 AM - edited 06-04-2018 12:56 AM
@Cheetah24 wrote:
Hi,
All plans except for 10 day ones are eligible. For more info, please take a look at the following thread:
https://productioncommunity.publicmobile.ca/t5/Rewards/Who-can-earn-Rewards/td-p/426
Cheers. 🙂
PM no longer has any 10-day plans and hasn't had any for a while, so in effect, all currently offered plans are eligible for the $2 autopay reward or any other rewards.
06-03-2018 08:48 PM
10 days plan doesnt have auto pay off. unless you are talking about something else.
06-03-2018 08:38 PM
@Lg85 wrote:The autopay reward will be applied on your next billing cycle once you have registered your credit card for auto pay. It doesn't happen immediately. Also, as mentioned above, $10 plans are not eligible for rewards, but if you change your plan to the 30 day or 90 day ones, you will receive rewards.
Just a correction, I think you meant 10-day plans, rather than $10 plans 🙂
06-03-2018 08:09 PM
06-03-2018 07:59 PM
ok i guess it just didn't tell me it worked yet. when i did a referrel it worked right away so i thought i was missing something. also if i move my plan from 10 days to 90 would that affect the rewards?
06-03-2018 06:59 PM
