01-12-2023 05:34 PM
I don't get a text message for voicemail notice.
I already set up a voicemail box but wonder if is there any other step to get a notice for the voicemail,
01-14-2023 01:05 PM
yes PM does not do text notifications. that's a visual voicemail feature and PM doesn't have visual voicemail
01-13-2023 12:29 PM
@sky1052 No text for VM alert.
You have to rely on the app notification from your phone's app. Do you have that set?
01-13-2023 12:27 PM
Are you sure that Public mobile doesn't do text message notifications of new voicemail?
01-13-2023 06:12 AM
@sky1052 Other carriers do text message notication of new voice mail. Public doesn't do that.
01-13-2023 01:04 AM
If you have a similar menu structure to this:
go into dialer, 3 dots, settings, Voicemail - what do you have in there?
back and Supplementary services, call forwarding - what all shows in the 4 settings
01-13-2023 01:00 AM
galaxy note 10. It worked in a previous mobile company.
01-12-2023 07:59 PM
01-12-2023 07:53 PM
Try performing a Reset of your device's Network Settings. This also resets Wi-Fi networks and passwords, cellular settings, VPN and APN settings, and connected Bluetooth devices that you've used before.
See if this resets things.
android:
Find and tap Settings > System > Advanced > Reset options > Reset network settings.
01-12-2023 06:23 PM
I don't receive a text.
I receive a "New voicemail" notification on the Android i use.
Open the "Phone" app, tap the 3 little dots upper right, then tap Voicemail.
There should be a "Notifications" tab wherein you can set various notification particulars to your liking, including sound, pop-up, vibrate, etc.
01-12-2023 06:14 PM
my android software is up to date
01-12-2023 06:13 PM
This is android system
01-12-2023 05:37 PM
@sky1052 @This is iOS issue get the latest update if you don’t already 16.2
01-12-2023 05:36 PM
@sky1052 are you using iPhone and on the latest iOS? there have been some posts about this no VM notifications after updating to the latest iOS
