09-01-2021 11:32 AM - edited 01-06-2022 03:16 AM
We will be out of country, but would like to keep our phone numbers for when we return. Is there not a vacation plan with a better rate?
12-28-2021 10:20 AM
If you have a grand fathered plan then you would lose it. If your plan is still available then you can change it back upon your return.
12-28-2021 10:20 AM
12-28-2021 10:11 AM
If I change to $15 plan before allowing my plan to suspend, I won't be able to get the plan I currently have back, correct?
Thanks.
09-01-2021 11:55 AM
@bobbanting no vacation plan. But how long you are going away?
you can move down to $15 plan if it is really short term.
You can suspend the plan for 90 days , and re-activate for a month , and then suspend for another 90 days
or you can port out to VoIP provider as suggested above
09-01-2021 11:47 AM - edited 09-01-2021 11:55 AM
You can port your phone number over to Fongo but you would be charged $25.
09-01-2021 11:45 AM
Excellent. My solution. Thanks loads bud.
09-01-2021 11:40 AM
@bobbanting wrote:We will be out of country, but would like to keep our phone numbers for when we return. Is there not a vacation plan with a better rate?
There are numerous ways to do.
How long will you be away for?
How many rewards do you have per month in dollars?
What plan are you on?
Do you have auto pay set up?
Do you have any data or? that was a promo when you joined up?
09-01-2021 11:37 AM
No formal vacation plan with Public mobile.
You could change to the $15 plan. Remove autopay. You can suspend your account for 90 days, pay again $15 and suspend another 90 days.
Here is an article:
