06-27-2022 09:34 PM
My Public Mobile cell phone will not allow another cell phone call to my phone.
Landline calls go through with no problem.
Cell phone callers do not get a voicemail. Usually the phone is disconnected after the first ring but occasionally an error message comes up..... 1H1 or 1V1 telling the caller I am unavailable.
Any ideas how to correct this??
06-27-2022 09:36 PM - edited 06-27-2022 09:42 PM
@peggyjohnson56 Try two things
1. try to reseat the sim card (power off the phone, take sim out for a minute before putting it back)
2. try to put the sim in another phone if you have one around, from friends from family
If you want PM to look into it, open ticket using one of the 2 ways
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
06-27-2022 09:40 PM
What is your area code (first 3 digits) of your phone number?
If it is a new area code for your area, some mobile provider may not be updated with the new area code.
06-27-2022 09:43 PM
area code 780
I have had this phone for approx 1 year with no problems until about 10 days ago
06-27-2022 09:51 PM
@peggyjohnson56 wrote:area code 780
Area code 780 is not new area code. Mobile phone be able to call you.
Test you SIM card in another phone of your friend or family member. Also use their SIM card in your phone. This will determine whether your phone has hardware related issue or not.
06-27-2022 09:55 PM
I do not have access to another cell phone. I live 12 miles from the nearest town. Possibly tomorrow I will be able to get someone else's phone to test the SIM in. This is a new SIM card just installed about 1 hour ago. The other one did not allow incoming cell calls either.
06-27-2022 11:56 PM
@peggyjohnson56 wrote:This is a new SIM card just installed about 1 hour ago. The other one did not allow incoming cell calls either.
@peggyjohnson56 this is a new SIM card? and you have an old one, so the 2 cards are both PM SIM cards and for different accounts?
(I hope you don't meant the new one is to replace the old one. )
Also, try to change the preferred network to 3G ONLY
