unable to call or receive call
mac1234
Hi I  got new sim card activated and also able to use the data but I am not able to make or rececive calls. Can you please help me
kselmak
One more thing, you are not on 1g data only plan, right?
cavemantoronto
Can you text? If yes, phone might only have LTE.  You need 3g for phone calls. Try setting that in phone settings.
geopublic
@mac1234  Are you porting your number from another provider? If yes, that might be why you can't receive.
  1. Did you check to make sure your device supports 3G B2 and B5?
  2.  Restart your phone and test dialing out.
  3. If did not port your number and you did make sure your phone is compatible and you did restart your phone and it's still an issue then submit a ticket for further help.
Submit a Ticket
ChuckYeah
Can you hold down your "1" on the dialpad and call your voicemail? Can you dial 611?
If not, your going to need a Moderators help, I think.
Creating a support ticket:
Explain your issue to SIMON, seen below
SIMON
Use as few words as possible to allow the BOT to understand. Answer his questions until you get to here:
Create a support ticket
Click on "Submit a ticket" and the Moderator team will take over your case and respond to your concern within 48 hours. May take longer, but the promise of the new Ticketing System was that it will reduce these wait times.
About @Moderator_Team
Moderator Hours
Monday-Friday: 8AM- 12AM EST
Saturday & Sunday: 8AM-10PM EST
kselmak
What phone are you using?
Did you restart the phone with sim in it?
Can you borrow another phone to test your card, make sure they the phone can go on Telus/Koodo network?
For talk and text to work properly for public mobile phone must support umts 850 and 1900 frequencies.
If your phone is ok you will have to contact Moderators for help er through Simon by clicking on the question mark
