trying to port number tells me is not a canadian number
echeverriadan
im activating my sim card and trying to port my number from rogers and it tells me is not a canadian number
2 REPLIES 2
@echeverriadan
the error " is not a canadian number" is either because
  1.  you are trying to port in from Koodo prepaid
  2. or  you have attempted activation once and saw some error and you decided to re-attempt to activate a second time.  But the early activation attempt was holding up the porting request
If you are porting in from Koodo prepaid, you have to activate with a new number first.  Once activation completed and you can make calls and recieve calls, then you will need to open ticket with PM support for a manual porting request.
if you are NOT porting in from Koodo prepaid but was re-attempting the activation a second time, you will have to open tickte with PM support and have them to clear up the earlier activation attemp
Please open ticket with them by direct message:
@echeverriadan
Check to see if your number can be ported to PM:
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do?lang=en&appname=otherportal
If It can be ported, contact a CS_Agent to help you complete your porting.
