trasnfering my esim
moonyi
Im trying to activate my public mobile sim card. Initially I tried to create a phone number, then it said it would send a code to the new number. however it has not been activated to so i am unable to continue.. to verify my account.
2 REPLIES 2
HI @moonyi since you already go to create phone number, you certainly using the app
you got to the esim installation screen yet? you got a Welcome email? there is a QR code there you can scan it to install
or check your sim manager and see if there is already a Public Mobile esim installed and just not active yet
and what brands of phone you have?
@moonyi  Are you using the app to activate not website ?? All activation need the app . Also in you phone setting check the sim manger and ensure PM sim is enabled /set to primary and reboot the phone . If still no luck submit ticket with support
send  a  private message   To CS_Agents
