03-03-2024
03:42 PM
03-03-2024
08:14 PM
computergeek541
03-11-2024 11:19 AM
Hi TheSterlinger - the link worked; but they require a promo code AND a telephone number ( I assume a referral code) if you have same or know of one I'd be grateful thanks John
03-11-2024 10:11 AM
Hi hTideGnow
Thanks - that 'semi' worked... They might do it if I have a 'promo' code (of which there are MANY) BUT AND a telephone number of which there are none. So if you have your referral code and a tel number and you would let me use it we both might win! Thanks John
03-03-2024 08:14 PM
@TheSterlinger wrote:You can submit a ticket to a Public Mobile CS agent with the link below.
Please note that the chatbot or the Public Mobile app should be used to submit all tickets.
03-03-2024 03:48 PM
thanks!!
03-03-2024 03:44 PM
03-03-2024 03:43 PM
HI @Aarhus
it's ok. Not late. Support agent can add it back
you just need to submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
