07-13-2022 07:57 PM
My loyalty and rewards are not appearing on my account although my account is still on Auto-pay. I have manually added a $15 amount today (July 13) one time-payment with a new credit card. The message says the funds are added successfully. My due date is the 16th of July. Update / restore my account with previously awarded loyalty and auto-pay rewards.
thanks
abdul aleem
07-13-2022 09:00 PM
The date in your rewards account is wrong. Your renewal is the 16th. Rewards are added to your account balance shortly after midnight eastern on your renewal date.
07-13-2022 08:23 PM
yes it renews the 16th. i checked my rewards portal and it is now showing that my two rewards will be applied as of the 17th. thanks for your help!
07-13-2022 08:15 PM - edited 07-13-2022 08:17 PM
@rambunny1800 Yes, the loyalty/autopay/RAF (if any) always get added to account on the day of renewal which you said isn't until July, 16th. edit: or perhaps on the 15th...
07-13-2022 08:10 PM
I already paid manually on my account but my loyalty and auto-pay rewards have not returned yet. I paid early because I got a text saying I had insufficient funds in my account even though I'm on auto-pay and have never gotten a message like it before. will it add automatically within the next few days?
07-13-2022 08:07 PM
ok thank you
07-13-2022 08:04 PM
is should be automatically add to your account
clear cache and cookies and use inPrivate mode
07-13-2022 08:01 PM
@rambunny1800 Your rewards will get added and offset against your bill on your payment date. To view the rewards, you need to select the down arrow under My Account and select My Rewards and sign in using the same email and password for your self serve login.
PM has also made changes that came into effect today for the self serve account and new 4G plans and there have been delays trying to log into the account because of higher than normal traffic.
Make sure to clear your browser cache/cookies and use incognito/privacy mode before retrying.
07-13-2022 07:59 PM
@rambunny1800 hi there have been issues with the new system all day,it should clear up in a day or two
