10-03-2020 04:12 PM - edited 01-05-2022 05:09 PM
My first month I signed up for the $25 plan - however I have decided to go to the second month using the $15 plan. I went online and put $15 into my account which it shows in there for a balance. I just received a notice on my phone that I do not have enough money in my account to renew. My plan expires tomorrow - is there something that I need to do = I was assuming that they would renew my plan to next month and take the $15 dollars I have in the account.
10-03-2020 08:21 PM
@billysmustang don't worry about it, if you have the $15 in there it will work, just keep an eye on it. if you're really anxious then just add another $10 to make your "available funds" to $25. as said, public mobiles system is reading your current plan, not the plan you wish to change too
*note your self serve account will show expired, suspended, active. this is how the renewal process works. if you have service just ignore the warning
10-03-2020 04:50 PM
This is a glitch in the system as its reading your current plan ($25) to be what is owing rather than $15 which is the new plan you've chosen. You've done everything correctly and since you have scheduled to change at next renewal it will. @Anonymous method will just assure the system that the glitch is happy too. You can do that for your own piece of mind and you may want to add the $5/500min calling add on later on for insurance so that you don't run out of minutes on your new plan. It will roll over each month until depleted. Many members do this on the $15 plan....,the add on can stay for years if you only occassionaly use a few extra minutes every month.
10-03-2020 04:37 PM
Yes you need to actually proceed to changing the plan for next renewal. It would be suggested to have $25 in your Available Funds to make the switch go smoothly even though you might not have autopay on. Then the excess can be used for your next renewal.
10-03-2020 04:18 PM - edited 10-03-2020 04:19 PM
@billysmustang wrote:My first month I signed up for the $25 plan - however I have decided to go to the second month using the $15 plan. I went online and put $15 into my account which it shows in there for a balance. I just received a notice on my phone that I do not have enough money in my account to renew. My plan expires tomorrow - is there something that I need to do = I was assuming that they would renew my plan to next month and take the $15 dollars I have in the account.
@billysmustang Did you actually change plans and select change at next renewal or just added the funds? You need to click the Change Plan option and select the $15 plan from the plan selections under Account Status of the overview page.
10-03-2020 04:17 PM - edited 10-03-2020 04:17 PM
Plan changes are never automatic. You have to logon your account and make a request to change your plan.
More info on plan changes here: https://www.publicmobile.ca/en/qc/get-help/articles/change-your-plan
10-03-2020 04:15 PM - edited 10-03-2020 04:36 PM
@billysmustang You need to go into your selfserve account and setup an immediate plan change.
Edit: Additional info:
When you’re changing your plan, you can choose to change immediately or at your next plan renewal date. To change your plan: sign in to Self-Serve, select ‘Change Plan’ on the Overview page, select the plan you want, and scroll to the bottom of the page.If you’re looking to apply a promotion to your plan, learn how you can do that here.Changing your plan on the next plan renewal dateWe recommend you choose this option because it allows you to use the services you have already paid for until your next plan renewal date. Here are some things you should know about this option:
Changing your plan immediatelyYou may choose to change your plan immediately if you have used all or most of your services, or if your account is suspended and you would like a different plan. Here are some things you should know about this option:
What will happen if my payment wasn’t completed? In this scenario, your account could still move from suspend to active, re-starting your plan cycle and potentially only reactivating a portion or none of your services. If you find yourself in this situation, simply go to the “Payment” tab in Self-Serve, choose “One Time Payment”, and opt to pay the “Amount Due”. This will cover the new plan cost less any partial payment that was taken. After successful payment, your services should be fully reactivated. If your services aren’t restored,please start a conversation with our virtual assistant, SIMon, to submit a ticket to the Moderator Team by clicking here.
