08-04-2022
10:05 AM
08-05-2022
04:11 AM
computergeek541
i have changed all the apn settings to the ones i found in this community and i still can't get my pictures to download in text. i have a blackview a80 plus phone. what else could i do?
08-06-2022 07:21 PM
@chantau try Reset network settings -
Also, check if you have RCS enabled or Chat Features on your device turned on, try turning those features off. They require a wifi connection or data to work.
08-04-2022 12:04 PM - edited 08-04-2022 12:06 PM
Now that I found the correct thread.....I can't remember why I thought knowing your phone's compatibility was important?🤔
Oh well I will post them anyways maybe it will jog my memory......
| Technology | GSM / HSPA / LTE |
| 2G bands | GSM 850 / 900 / 1800 / 1900 - SIM 1 & SIM 2 |
| 3G bands | HSDPA 850 / 900 / 1900 / 2100 |
| 4G bands | 1, 3, 7, 8, 20, 40 |
| Speed | HSPA 42.2/5.76 Mbps, LTE |
08-04-2022 10:54 AM
data must be on if it is try your setting as
08-04-2022 10:33 AM
A80PLUS_US_M657A_V1.0_20210312V05_20210312-1422
this is the version it gives me
08-04-2022 10:20 AM
Try to edit your APN to this one....then save and reboot.
Name
Mobile Internet
APN
sp.mb.com
Proxy
Not set
Port
Not set
Username
Not set
Password
Not set
Server
Not set
MMSC
http://aliasredirect/proxy/mb/mmsc
MMS proxy
mmscproxy.mobility.ca
MMS port
8799
MCC
302
MNC
220
Authentication type
Not set
APN type
default,mms,agps,supl,fota,hipri
APN protocol
IPv4
APN roaming protocol
IPv4
APN enable/disable
APN enabled
Bearer
Unspecified
MVNO type
GID
MVNO value
4D4F
08-04-2022 10:18 AM
it's a new phone. i did receive some pictures from a friend that downloaded no problem while others from her and a different contact cannot download
08-04-2022 10:16 AM
Are you able to edit and save your APN in your phone? What version of OS is your phone running?
08-04-2022 10:14 AM
And this is first time MMS is not working as expected. You did send/receive pictures before?
It could be some outage at PM?
08-04-2022 10:13 AM
You may need to reset your APN setting on your phone. You can find out how to do that here https://apn.global/ca/public-apn/
I have found occasionally when the phone updates it reverts back to default APN. I was having issues and this was the case.
08-04-2022 10:10 AM
yes my data is on
08-04-2022 10:09 AM
Do you mean MMS does not work?
Your DATA has to be On even though MMS will not use it. Set DATA to On and try again. Same as for sending.
