05-03-2025 04:09 PM
When I was adding public mobile i accidentally put it on my phone and am having issues getting the esim transferred over to the right phone
05-03-2025 04:29 PM
@Rilynn If I understand the problem correctly - you can't transfer an esim from one phone to another on Public Mobile. You need to download the PM app on the "right" phone, log in to your account and then purchase a new esim. If you already have an esim there should be no charge for the new one.
05-03-2025 04:28 PM
hi @Rilynn there is a chance you need to get a physical sim card first and change back to eSIM later
but check with PM support agent first
you can submit by direct message:
05-03-2025 04:23 PM
