number portability
MaxBokalo
При переносе номера я неправильно указал ESN or MEID.
@MaxBokalo
Porting your number to PM is to use your previous account number from your previous carrier rather than using the IMEI number.
Contact a CS_Agent by pm them directly.
Neil11
You will need to contact customer service agent to fix your issue. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
MaxBokalo
When transferring the number, I incorrectly indicated the ESN or MEID.
