05-11-2021 01:40 PM - edited 01-06-2022 02:02 AM
when i try to make a call it says the number is long distance which it isn't, when someone tries to call me they get a busy signal
05-11-2021 01:54 PM
account is good
05-11-2021 01:53 PM
no long distance on this account when i tried my land line which is a local call ?
05-11-2021 01:47 PM
@annnicholson : What do you get when you dial 611? Maybe your account went into suspension.
05-11-2021 01:44 PM
# 1. To get the obvious out of the way...you used 011 or +1 in front of the country code? Sometimes there are some extra leading zero's in country codes and "foreign" area codes. Maybe try not using leading zeros.
# 2. do one thing take your SIM card out and waiting for a minute and put it back and do rebooting your phone is will working,
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
Good Luck
