06-01-2023 07:01 AM
I had to create a new profile due to the new system not accepting my community login info. Is there a fix for this yet? I am a regular here in the community.
06-01-2023 01:32 PM
LoL
Welcome back. 🙂
06-01-2023 01:30 PM
@softech I had to go through eversafe to update my account password. My community login is different, as is the password. Usually I keep the page open and don't log out of the community page. This morning, I was logged of out the community so I had to go through eversafe and that's when the issues started. My old password wasn't secure enough, so I had to create a new one. Once I created a new password, a new profile was created. Unfortunate but a little patience and everything was fixed by Carlos. 😊
06-01-2023 01:12 PM
@DDM69 Hahahah feeling BRAND NEW !
06-01-2023 01:10 PM
@DDM69 but you using your name still last couple days. What happened today?
06-01-2023 01:09 PM
RESOLVED! I'm back! Thank you agent Carlos 😊
06-01-2023 08:00 AM - edited 06-01-2023 08:01 AM
@Anonymous wrote:Thanks folks. I'll try to reach an agent...
DDM69
@Anonymous you are @DDM69 ? I thought you are ok. I saw you posting after the upgrade.
06-01-2023 07:24 AM
DDM69
06-01-2023 07:09 AM
@Anonymous Sounds like your one of the ones affected by this thread
bravo the post and support will work with you
if you don’t hear back in a day message support directly
06-01-2023 07:09 AM - edited 06-01-2023 07:10 AM
Definitely reach out to the customer support agents @Anonymous
You shouldn’t have to forfeit your community account and I can’t imagine there isn’t a way for them to associate one to the other.
Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request). Click the result which states Click here to submit a ticket and follow the prompts, or,
Send a private message to the Customer Support Agent by clicking here You’ll need to be logged into your Community account for the link to work.
06-01-2023 07:07 AM - edited 06-01-2023 07:10 AM
@HALIMACS I've already had to change my community password. I just want my normal username back. Also, I probably won't get credit for my participation this past month.
I was able to migrate my account easily. However, I was always logged into the same community account for the last week or more. For some reason, I was logged out last night and could not log in using my same simple password. Once I changed it using eversafe, I needed to create a new community profile.
06-01-2023 07:03 AM
Try again using a desktop or laptop in incognito or private mode. I did not have any issues migrating to the new system.
