4 weeks ago
My son has been getting no service on his phone for a couple weeks now. I replaced the sim and no change. there are 4 of us in the house who all use public mobile and 3 of us have no issues. Any suggestions on how to fix his phone, its a samsung s22 and this issue just started randomly and I figured for sure a new sim would fix it. Really need to get his phone working again. TIA We live in the WIndsor Es**bleep** area, if that helps
3 weeks ago
So the Not Registered on Network is a device issue? Why would it have just started randomly?
3 weeks ago
if you tried 2 different sim cards and both not working on your son's phone but it is working on another phone, it is likely a device issue, could be a sim card reader problem
you can try Reset your phone to factory and see if it helps. If the result is the same, you probably have to get him a new phone
3 weeks ago
It is not blacklisted
3 weeks ago
check if your son's phone is blacklisted
3 weeks ago
So when I put my sim in his phone and tried to make a call it displayed Not Registered on Network. NOt sure what to do now. HIs sim worked fine in my phone
4 weeks ago
I will give that a try tonight when he gets home, and update, thanks
4 weeks ago
does your son has a physical sim? did you try his sim card in another phone? or test other sim card on his phone?
and check if My Account and see if account is active. Since you have multiple accounts with PM, when checking My Account, please use browser with incognito mode to avoid cache problem
if still unable to get his account/sim working, please engage support for further assistance
Please open ticket with PM support:
4 weeks ago - last edited 4 weeks ago
@dennisjd Can you try his SIM card in one of the other 3 household members phone and see if it works and then get your sim in his phone . This will help to determine if it’s account related issue or a device issue to start troubleshooting
