01-07-2022
05:17 PM
01-07-2022
05:20 PM
computergeek541
after I transfer my number from charter mobile provider can not receive incoming call
edited: label correction - community to joining public mobile
01-07-2022 07:52 PM
@Gidey wrote:after I transfer my number from charter mobile provider can not receive incoming call
If you just ported your phone number from another cell provider it could take a few hours to complete the port.
Using the other cell provider's SIM you should be still receiving calls on it, until the port completes.
Make sure you do not cancel your previous provider's services.
Incoming calls are usually the last to port over.
Check your Private INBOX messages, I have sent you the TELUS Porting phone number.
Or, alternatively,
If issues porting or transferring a number to Public Mobile, and it has been over the allotted time it usually takes to complete, submit a ticket here for help: https://widget.telus.tiia.ai/chatbot.html?botId=ZJkWuVb7Hp6EEcTIZKMZbvLwuDV&duid=1ml7MK2dvkmM37lFcEM...
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
01-07-2022 05:20 PM
do you get a SMS message from your old carrier asking to confirm if you would like to Transfer your number. Your reply should be: YES.
if you stuck with Transferring your old Phone Number, or is not complete processing
Here’s how to contact Customer Support Agent by CS_Agent,
you can try to do some troubleshoot
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
APN Settings On An IPhone
click Here link,
or visit Here link,
APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
Select the brand and model of your phone,
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is meant by rebooting the device turn off and turn it back on.
try to check update your device,
you can try to test your SIM card in another device to you know the issue from SIM card network or your device issue.
01-07-2022 05:19 PM
This means that porting is not complete. Please re-instert your Chatr SIM card. You must reply to a text message that Chatr send you to approve teh phone number transfer. This message will only be received if you are still using the Chtar SIM card. Also, your incoming calls would still be going there (to Chtar).
