new phone transfer
wheeler2025
so we went to set up a new phone and transfer,  but now the eversafe has a two step authentication and the second step texts a code to the number not in use.  so no way to login to the account
Your kid account needs PM to help to sort out the login issue to re-buy eSIM.   Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
wheeler2025
my kid ported the data over using the house wifi, but calls and texts are lost as esim was on old phone which he reset
RavingRaven
@wheeler2025
You requested porting of your phone # during activation? Did you reply YES to the porting authorization text? Is your Public Mobile sim card working with full services? ( Data, incoming/outgoing texts and calls?)
