my phone is not working in us. i bought add on
tuvia
hi. i have bought a canadian plan for $15 and a add on of $15 for unlimited us roaming talk and text. why doesnt it work? is it beceause it is a 3g plan?
dust2dust
Are you in the US? Text should be fine. The roaming setting is usually only for data
dabr
@tuvia    Are you able to connect to T-Mobile and then select 2G network mode?  The talk part has become a problem since the US carriers shut down 3G network, however, text and data are supposed to be unaffected.
Try rebooting the phone and make sure roaming is enabled.
Peter-AB
Hello,
You should verify that "roaming" is enabled in your settings.... hope this helps.
@tuvia
Which city and state you are at?
check which network you are connected to.  Try to manually connect to T-Mobile and see if it works
kaytus
@tuvia did u set up the roaming for your phone?
