11-14-2022 05:33 PM - last edited on 11-14-2022 06:51 PM by computergeek541
Usage says 65 minutes but I counted (twice) 45. Anyone know how to talk to Public about it?
11-14-2022 08:26 PM
Thank you Softech! That's the information I was looking for. Any idea what the ticket efficiency is like?
11-14-2022 06:50 PM
Hi @MistaC and make sure you aware your cycle date change, not always on the same day of each month. So, make sure you know the exact date of your first day of your current cycle.
If you checked again and still off, open ticket with PM Support
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
11-14-2022 06:48 PM
I'll give that a try though I did verify against my phone's log. Same result.
11-14-2022 06:37 PM
HI @MistaC
did you just use the filter option on the Usage History page?
There is a problem with the filter on the page and it won't give you all the entries. Please download the full usage history in xls and then use Excel to filter and sum up that way
Remember to round up to the next minute
11-14-2022 06:32 PM
I mean the service month. For me it's October 29 - November 28. That's the period at issue.
11-14-2022 06:28 PM
There's a keyword in there - "month". Go back to the beginning of the renewal date. Not the month. If that's possibly being misunderstood.
11-14-2022 06:07 PM
I have lots of extra minutes. The problem is where are my missing 20 minutes? And how do I talk to the admin about it?
11-14-2022 06:05 PM
Consider getting the $5 / 500 minutes of Canada wide calling add-on. Good to have for your type of plan with limited minutes.
The add-on minutes will take over if you go over your plan minutes...and any add-on minutes remaining at renewal will roll over until you use them up...even if that takes several months or more.
11-14-2022 06:01 PM
Yup, rounded everything up and counted the voicemail minutes too. Like I said, counted twice. Even added on the day before the month started.
11-14-2022 05:35 PM
HI @MistaC did you round up the minute to the next minutes?
A 1 minute 1 second call actually will be counted as 2 minutes. All carriers are like this
And calling voicemail from your phone will be counted as well
