lost phone
Winter20
My phone stolen and I cant get intomy naccount because I cant remember my Pin Mumber
@BKNS27
actually, you can use Google Find phone service for Samsung and non-Samsung phones as well.  Use the Google link I posted above
@Winter20
If it was an iPhone or Samsung phone, you can login to your Apple account or Samsung account and track your phone on Find My.
maximum_gato
@Winter20
You don't need your pin # to access your account just your email/username and password. Or do you mean you can't reset your password? If you can access your email for the verification code but can't recieve it try logging in on a desktop or laptop computer if you have access to one?
@Winter20
open ticket with PM support to get back to My account as advised by @HALIMACS
and some advise to what to do once you got the access back
, you might want to first supsend your service first until you got a replacement sim card;
Login to My Account, from Quick Links on the top right, click Lost/Stolen Phone
Then get a Public Mobile sim card from
Once you got the sim card, go to My Account from ONLY a desktop or laptop computer to request Change Sim card (please note that due to some glitches, accessing change sim care from mobile phone or tablet won't work)
After you logged in, unsuspend first if you have suspended your service earlier.
Then click Quick Links on the top right and select Change Sim card and follow the steps from there.
And for your lost phone, maybe you can   use  the FindMy service to locate the phone and try a remote wipe
Apple: https://www.apple.com/ca/icloud/find-my/
                 (how to use: https://www.pcmag.com/how-to/find-a-lost-iphone)
Google: https://myaccount.google.com/find-your-phone
Samsung: https://findmymobile.samsung.com/
               (how to use: https://www.pcmag.com/how-to/how-to-find-a-lost-android-phone)
HALIMACS
@Winter20
After getting access by contacting the Customer Support Agents as below, go into the account and set it as "Lost/Stolen".
  1. Use the ticketing system for a faster response time. Click here to create a support ticket, or
  2. Send a private message to Customer Support Agent by clicking here.  You’ll need to be logged into your Community account for the link to work.
