11-22-2022 05:24 PM
11-22-2022 05:48 PM - edited 11-22-2022 05:53 PM
Yes...log in to your account / Plan and Add-ons / look to the right side and find Shop Add-ons... Click and then click Minutes...3rd selection down is 1000 US calling minutes for $15.
editd
11-22-2022 05:44 PM
@rosiemgh wrote:"can the add on be done now for 1000 US long distance minutes $15"
Yes , you can.
11-22-2022 05:42 PM
11-22-2022 05:37 PM - edited 11-22-2022 05:37 PM
hi @rosiemgh
just login My Account, go to Plan & Addons page to buy
But try the free solution I suggested above
11-22-2022 05:36 PM
@rosiemgh wrote: "Can you add on now?"
Login your self service account then buy add-on, make sure you have enough fund in your account.
You could try textnow or textme app some kind of apps to call USA.
11-22-2022 05:33 PM
Hi @rosiemgh PM used to offer plan with US calling but no longer.
Download app to make free US call instead. TextNow is a good choice
11-22-2022 05:32 PM
Can you add on now?
11-22-2022 05:31 PM
@rosiemgh If you want to call USA, you must buy 1000 U.S. Long Distance Minutes for $15 dollars.
11-22-2022 05:27 PM
I do not think PM has plans including Canada wide and USA calling.
You can always purchase US calling add-on
11-22-2022 05:27 PM
There used to be US calling included in some plans. No more. The only way now is to buy the 1000 minute add-on.
