01-19-2025
09:08 PM
01-19-2025
11:42 PM
computergeek541
01-19-2025 09:26 PM
just in case you are existing customer, then it is easy. After you got the sim card, login My Account, go to Profile and update the sim card number. Then put the sim card in the phone and reboot and bingo!!
01-19-2025 09:18 PM
@lxh wrote:but i would keep my previous number, what is the right way to process ?
Thanks!
What do you mean your previous number? Were you a customer here before in the last 89 days or are you talking about porting your number from a different service provider?
01-19-2025 09:17 PM
@lxh wrote:how to save $10 for the sim card?
Thanks!
Another option @lxh is you can buy an eSIM which is $5 if your phone can do one. Best part, if you lose your phone or get a new one, you just download another and it's free! If you lose your phone, you keep paying $5-$10 each time for a SIM card. Just saying there are options.
01-19-2025 09:16 PM
you can still do it even you got the sim card from Amazon
01-19-2025 09:14 PM
Thanks!
01-19-2025 09:09 PM - edited 01-19-2025 09:09 PM
buy the sim card from Amazon for only $5:
https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/dp/B06X9ZGDWG
and then get a $10 worth of friend code to use to join PM. So in the end, you earn $5 🙂
