how to cancel redemption
yx1997
I accidentally redeem twice times, how do I cancel for one?
10 REPLIES 10
HI @yx1997
you need to see if CS agent can help
Please submit a ticket with agent at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
you need to open
@yx1997   it said within 24 (or 48 hours?)  But someone tested it and confirmed it is instant
Try to login My Account using Incognito mode and check if you see it there
yx1997
thanks for the link
yx1997
I just make redemption as add one for extra 200 MB
email says it takes 24 hours
I have not seen the add-on on my account yet
@yx1997 wrote:
I don't figure it out, how to get redemption points? by answering people's questions?
@yx1997 Yes, basically help out others by answering questions
Welcome to the Community
HI @yx1997   you are talking about Give-Back rewards points, you are in the right place
Just answer questions you know, earn bravos and give bravos for good posts.  Sorry, we don't know how much participation is needed.  Just keep participate 🙂
XionBunny
That or general participation on this forum.
@yx1997 - well, we cannot help you with that.
Submit a ticket to CSA and let them know what happened, and ask nicely to reverse one.
­­­Public Mobile Representatives customer support­­­ agents (CSA) can be contacted by either two methods, found here:
yx1997
