06-05-2023 11:43 AM - last edited on 06-05-2023 06:29 PM by computergeek541
06-05-2023 01:28 PM
thanks @umnikke8
let me check mine, too
06-05-2023 12:48 PM - edited 06-05-2023 12:48 PM
@umnikke8 , on my iPhone 14 Pro it has a check mark on incoming calls & says Calls with a check mark have been verified by the carrier.
06-05-2023 12:47 PM
And for clarification, this isn't something you activate, the network is doing all the work and sending notification to your phone of the results along with the call.
06-05-2023 12:44 PM
@hTideGnow my iPhone is several years old. Stir/Shaken authentication doesn't need anything special in hardware, it's just a software flag, so old phones shouldn't have any problem with it, just need a supported OS. I believe iOS 13 added support for it.
06-05-2023 12:41 PM
HI@umnikke8 what iPhone you got? only the newest one has the feature, I think. Not sure if iOS update helps older phone
06-05-2023 12:40 PM
I noticed my first few calls with the checkmark in iOS that indicate Stir/Shaken authentication has occurred. I believe this requires VoLTE to be used, the first one in my call history is from April 28. I think all iOS devices running VoLTE support Stir/Shaken, but all they do is put a checkmark in your call history to show it was authenticated. It's not used for call blocking and doesn't even show when a call is ringing. Someone else can chime in with Android support for it as I haven't kept up.
06-05-2023 12:03 PM
@Babu2 I believe most phones on the market now still not compatible with STIR/SHAKEN
https://www.telus.com/en/support/article/stir-shaken-mobile-devices-explained
