forgotten username public mobile login
boondock69
Hi,  I have forgotten the email or username that I used on my 10 year old account.  Trying to add an addon is impossible without these.   Any help would be appreciated bigly.
Thanks
10 REPLIES 10
@pmmobile wrote:
@Ed404Does calling 611 use up minutes or is it a free call? Thanks!
@pmmobile  it's free.
pmmobile
boondock69
Thank you for the advice and the link to the ticket.
Cheers.   Great community!
boondock69
Ya,  Thanks for the reminder.  I made that very mistake when I first signed up.  lol
Ed404
@boondock69 wrote:
I have the alternate email and or phone number if that helps.
When the moderators change your email to your new one, make sure it matches your community account @boondock69 so you can claim community rewards if you participate enough.
Frigg
You will need the help of the moderator...
and explain what happened...you need to wait few hours or up to 2 days...they will answer you and help!!!
Or
Create a ticket at; click https://publicmobile.ca.ada.support/chat/
boondock69
Thank you Ed.  Exactly the info I was hoping to find.
boondock69
Thanks
Triguy
To purchase an Add-On using this method, you will need to have a payment card registered to your account. Find out how to register your card in Self-Serve here. Dial *611 on your phone, and follow the prompts to first make a payment using a Public Mobile payment voucher, credit card, or Visa Debit card. After adding funds equal to or greater than the Add-On you wish to purchase, follow the prompts to buy an Add-On. You will need your 4-digit account PIN to purchase an Add-On. You selected your PIN when you activated your account.
Ed404
You can purchase an add-on by dialing 611 if there is a credit card on your account. If you forgot your email then you need to contact the moderators by submitting a ticket by clicking the green ? in the bottom left corner and click "Click me" under Submit a Ticket.
