04-26-2023 03:23 PM
Hi, i ordered a phone from Public mobile and to date i have not received it; how can i find out where it is ?
04-26-2023 04:46 PM
@Yellowstone1963 wrote:Hi, i ordered a phone from Public mobile and to date i have not received it; how can i find out where it is ?
@Yellowstone1963 , I received my phone from Public Mobile within 3 days of ordering it. It was delivered by UPS. I was able to track my phone order without getting my tracking # from Public Mobile by using my delivery address on UPS app which in turn showed my tracking # allowing me to track my order to know when my phone was being delivered!
04-26-2023 03:39 PM
thank you!
04-26-2023 03:26 PM
check if you get the tracking email from PM, they might or might not send it, so, at least check the email first
and submit a ticket with PM agent and ask them where is the phone:
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
04-26-2023 03:26 PM
@Yellowstone1963 how long it has been? CPO order usually within a week or two
and did you get any email?
For status update, please open ticket with PM support and provide them your order number
1. Please open ticket via Chatbot (requires access to My Account): click this Chatbot Ticket Link
Then click "Click here to submit a ticket ↗" to open the ticket submission page
Next, enter your Community login, then enter your question. Finally use My Account login or 4 digits PIN to validate.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
