data doesn't work on new Moto G8 power lite phone
chrisgus
My data is turned on but not working on my new moto G8 power lite phone
2 REPLIES 2
Hello @chrisgus
Do your calling and texting services work okay?
Try one or more of the below:
*turn off your phone, leave off for a minutes, then reboot
*removing your SIM for a few minutes, then reinserting it
*go into airplane mode for a few minutes, then going back to regular mode
*reset network settings
*if your phone locked to its previous provider? Contact your previous provider to unlock it for you.  You will need your imei number, dial *#06# to get it.
Check APN settings through this way:
1. Tap Settings.
2. Tap Connections.
3. Tap Mobile networks.
4. Tap Access Point Names.
5. Tap the access point you'd like to check.
The first thing you're going to want to check is to ensure that your APN settings are correct. Here's a good starting referrence:  https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone
