11-28-2022 09:43 PM - edited 11-28-2022 09:46 PM
it states : " After you join, you'll also earn 10 points for every 12 months you stay with us "
is it cumulative as in per 12 months per 12 months ? i.e. 10 points after 12 months and then after another
12 months does it become 20 points.... and so after 36 months it would be 30 points.
or is it just a disappointing 10 points every 12 months year after year after year ?
because you see earn 10 points for every 12 months you stay with us...... means to me i would get 10 points
after staying with you for 12 months and then after staying with you for 24 months i would get 20 points because
that is 10 points for every 12 months that i stayed with you.
do you see ?
11-28-2022 09:45 PM - edited 11-28-2022 09:46 PM
The way I see it is 10 points every 12 months. Not cumulative like the old rewards program.
Edit: That is one of the reasons so many old customers did not switch.
11-28-2022 09:45 PM
HI @ptrjpm NO. the Anniversary point is 10 Public point and always 10
So, on your 1 year annivesary, 10 point, on your 2nd anniversary, 10 point..
