09-06-2022 12:05 PM - last edited on 09-06-2022 12:19 PM by srlawren
09-06-2022 12:34 PM
Thanks Meow.. All good.
09-06-2022 12:32 PM
@softech wrote:@dust2dust , @Meow can you modify your replies and make some small changes so the subject line will update to take away the phone number as well? thanks
Sure thing! Subject line has changed. Anything else I can do?
09-06-2022 12:21 PM - edited 09-06-2022 12:22 PM
@lilyge you are one the right track...the change works
just one extra work, please come to your other reply
and modify and make some small change to the post and click save, then the phone number from that particular reply will be gone
09-06-2022 12:15 PM - edited 09-06-2022 12:19 PM
@lilyge you can update the subject line and the body text to remove the phone number. Just go back to your original post, click on the 3 dots on the top right click Edit Message. Make sure you remove the phone numbrer from the subject and body
09-06-2022 12:14 PM - last edited on 09-06-2022 02:00 PM by computergeek541
Go back up to your first message and click on the little down arrow on the upper right of it and select edit reply. Then edit your subject line and body to remove your number.
Then others can do theirs too if they wish.
adding - I replied to the later update. That hasn't been changed. So this won't change.
edited by computergeek541: phone number removed from title
09-06-2022 12:12 PM - last edited on 09-06-2022 02:24 PM by computergeek541
could you delete this message
09-06-2022 12:07 PM - edited 10-20-2022 02:16 PM
@lilyge wrote:change xxx-xxx-xxxx from $15 to $25 plan
@lilyge you have made the change and not successfully?
or you try to make the change and asking how?
Please login to My Account and make the change yourself
Go to Plan and Addon page, click Change My Plan.
Then all the plans will be there, use the yellow arrows on the far right to scroll up and down for the plan you want (the arrows can be at the bottom if you are using mobile browser)
09-06-2022 12:07 PM - edited 09-06-2022 12:31 PM
Please remove your phone number from public forum.
You can switch plan at any time by yourself but it is more prudent to schedule plan change on next renewal.
09-06-2022 12:06 PM - edited 09-06-2022 01:33 PM
You can do this yourself in your account. Can you login to your account?
adding - is this changing?
