can't make calls
andreyfaigon
i am new to PM . i just activated my sim, got new#, but nothing but nothig works. i tried to fit APN, doesnt help. my phon unlocked and previosly checked IMEI #
can somebody help me????
7 REPLIES 7
Rockdaddy22
Edited because I need to learn how to read.
Do you mean refund for your phone or from Public Mobile?
Public Mobile is 100% prepaid and is not required to provide a refund because you have the wrong phone. If you wish to try, send a private message to any moderator ( @Mary_M for example) with your phone number and an explanation of what happened. It will be several days befoe you have a reply.
If unfamiliar with private messaging, check here: Private Messages - viewing and creating.
Not likely but you can only try.
andreyfaigon
unfortunately my pone not working,and it seem like it not compatible. how i can receive refund, who can help me?
So, suggest you read http://productioncommunity.publicmobile.ca/t5/Phones-Hardware/Where-can-I-buy-a-phone-to-use-with-Pu... and the network frequency requirements in particular Public Mobile works on following frequencies:
  • For 3G use (UMTS/HSPA): 850MHz/1900MHz bands
  • For 4G/LTE use: 1700MHz/2100MHz bands
  • For 4G/LTE use: 700 MHz band
All phones, except for Koodo/Telus, MUST be unlocked.
Bad news I'm afraid. Our go to source for compatibility is http://willmyphonework.net. The report below says it will not connect to Public Mobile's network.
Device FrequenciesLenovo S660  Carrier Frequencies Canada Public Mobile
2G Network:
3G Network:
4G LTE Network:
Device not compatible
andreyfaigon
no service, it is lenovo s660, unlocked, dual sim,bought in Ukraine.
Luddite
@andreyfaigon Reboot your phone then report what message you see; No Service, No SIM, Public Mobile with bars, etc.?
What is make/model of your phone? Where purchased?
