can my account add one more phone number?
xpqhbsq
8 REPLIES 8
wellis
You can use a separate email to create another account for the number you wish to be supported by PM. Brief, you can not add more than one phone number to a single account.
For Each account with public mobile can only have a one phone number
for A second account
a new email
and you can use the same your address home
and the same your credit card
and all your information you can put it the samething,
just the Different for A second account you need a new email .as a many new line you like to Activate.
Good Luck
benfatto
@xpqhbsq  Yes, only 1 SIM per account but a way to simplify things here: workaround
@BKNS27 wrote:
@xpqhbsq
Sorry only one number/account/email address.
I would suggest you get a Google, Outlook, Telus or Shaw email account.
@xpqhbsq
Try gmail or outlook. And use an alias which works on PM but to you is still one email address.
I would NOT use Shaw or Telus email. Think in the future.....if you switch services and the PITA that it will create.
Spudster
@xpqhbsq
To get one more phone number, you'll need:
  1. a new Public Mobile SIM, look here for store locator
  2. a different e-mail address address, or an alias of your existing one being used.
Once you've got the above, use your referral code from your EXISTING Public Mobile account to activate another account/phone number.
@xpqhbsq
@xpqhbsq   , Just use another email to create a 2nd account for your 2nd phone number.
JK8
Each account can only have one phone number.
