10-21-2025 11:31 AM
hi, so i lost my phone and have a new one. what i need to do to port the number to my new cell.
i dont have physical card i did esim
10-21-2025 11:42 AM
yes, you will keep the same number as long as you login to the app and buy esim using the same Public Mobile login you have been using
10-21-2025 11:35 AM
ok so i will still be able to keep the same number,
10-21-2025 11:32 AM
of course you can
you need to download the PM app on the new phone, login and buy the esim from the app on the new phone. Can you do that now?
or if you have trouble logging in theapp now, ask PM support agent to help
You won't be able to submit Chatbot ticket if you cannot login, but you can still submit ticket by direct message:
