05-19-2022 07:31 PM
I have gone to the "shop phones" webpage and when I click on any of the listed phones (on the pic or on the "more detail" button) nothing happens. There does not appear to be a URL associated with the item. I have tried 4 different browsers (firefox, brave, chromium, duckduckgo) on 2 different operating systems (linux, android): all the same result. I have turned off ad block. There are no other questions about this in Community, so I'm thinking it must be me, but I am out of ideas.
05-28-2022 02:58 PM
Hi @nlach71 Telus owns PM, I wonder if the site refer any object there and make the ad blocker thinks it is not legit. But glad you have it figured it out
05-28-2022 02:56 PM
I posted the original complaint. Thanks for all the suggestions, but it turns out it was a (fairly obscure) ad block issue. I am using pi_hole LAN ad blocker on a raspberry_pi on my home network. It appears that pi_hole thinks that the link to phones and plans point to an ad site, so it throws it away. I removed the raspberry_pi from my network and all was OK, I was able to buy the phone.
05-20-2022 01:32 AM
Have the same issue, using Brave too.
05-20-2022 12:53 AM
I noticed the same on brave, but I also didn't investigate much ... But I was already in private mode 🤔
05-19-2022 11:52 PM
Any luck? I just tried it on my phone and my laptop with no issue
05-19-2022 07:38 PM
I just tried it and it seems to work ok for me using Firefox.
05-19-2022 07:37 PM
05-19-2022 07:37 PM
Did you try clearing cache and cookie then go incognito?
05-19-2022 07:36 PM - last edited on 05-29-2022 06:24 PM by Luddite
HI @nlach71 probably just a browser issue
try a different browser, firefox/chrome/edge
or Incognito mode
or clear cache
[browser ad blocker too aggressive ................ Luddite]
