06-22-2019 11:24 AM - edited 01-05-2022 05:30 AM
I know this has been asked mutilple times, sorry for being redundant!
I might be in a position to use all my data before the end my current 30 day cycle.
What are my options to early renew?
Can I do it myself by making an early payment and that would change my cycle date?
Can I also change plans at the same time if necessary?
Or do I need to contact a moderator to do it on my behalf?
Thanks in advance!
06-22-2019 01:35 PM
@hycm53 wrote:
@mynewhome wrote:I know this has been asked mutilple times, sorry for being redundant!
Thanks in advance!
You can't make an early payment and change your cycle date. You can change plans immediately but be caution you'll lost unused data,etc and won't get refund.
You can add on only 1GB data for $30 dollars or 200MB data for $10 dollars.
@hycm53 You can renew same plan early with moderator assistance. There is no refund of the unused days of the current cycle. Consider moderator wait time of 2 - 3 days to decide whether to renew the same plan early on not.
06-22-2019 12:41 PM
Thanks in advance!
06-22-2019 11:45 AM
You can upgrade your plan but it's not immediately, so easier way is you buy data upgrade and use extra data immediatly, and upgrade your plan to more data quota which will be effective in next billing cycle.
06-22-2019 11:28 AM - edited 06-22-2019 11:32 AM
@mynewhomeYou can do an early renewal with a different plan.. since it is a prepaid plan you will forfeit your current plan and the renewal date will start on the day you choose your new plan.
You can do plan change via this link
06-22-2019 11:27 AM
You will need moderator help to renew same plan earlier. Expect 1-2 day wait though.
You can switch to another plan immediately, but you will lose whatever is remaining in your original plan.
You could also buy $30 1 GB data add on. Unused portion of add on will roll over to next month.
