05-12-2025
08:32 PM
05-13-2025
10:29 AM
computergeek541
we were out of the country for a few months and our accounts have be canceled.... can we re activate them?
05-12-2025 08:50 PM
@mzt wrote:we were out of the country for a few months and our accounts have be canceled.... can we re activate them?
How long is "a few months" ? When your latest renewal failed due to non-pay, you have 90 days grace to re-up the plan. If you missed the 90 days, that account has been deactivated. You need a new sim to start a new account. If less than 90 days...just log in to your account, re-enable Subscription and Resume your account.
05-12-2025 08:44 PM
quite possible but it is up to PM and depends if the number was from another provider when you first go it. Please open a ticket with PM and they can confirm
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
05-12-2025 08:43 PM
hi @mzt
account will be closed if suspended for over 90 days due to non-payment. You might be able to get back the number, but you have to check with PM support agent yourself
you can submit ticket by direct message:
