01-06-2023 01:38 PM
I’ve made the mistake of buying the wrong add-on I needed. How do I cancel and get refunded, to purchase the right one?
01-06-2023 01:40 PM
@Aeb it is possible P. support can reverse the transaction, please open ticket with them using chatbot
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
01-06-2023 01:40 PM
@Aeb you will need to reach out to support and see if they can help with this
Getting help from agent , through automation
Or get direct help from a agent right here in the community ( my preferred choice )
