Why is my esim not loading to finish my transfer
Damigiano
7 REPLIES 7
@Damigiano  Also I’ll send you the porting team number to give status update on the port or re trigger it if need . Sending private message as we not allowed to post it here
Damigiano
I replied yes and didn't get a QR code
@Damigiano  Please use the link below in my first reply to you to contact support
JRod
@Damigiano
Please click this link below to message customer service to get them to resend the QR code to you:
Keep an eye on your mailbox here as that is where your reply will come in (envelope icon on desktop, click your avatar icon in the corner and then click messages if on mobile).
Damigiano
I didn't receive a welcome e-mail but they charged my credit card
JRod
@Damigiano
Have you tried to add the E-SIM using the QR code sent to you via email?
Also did you reply yes to the text sent to your old sim to authorize the port?
Ensure the E-SIM is active and is the only SIM currently in use. Then reboot your phone.
@Damigiano  Check your welcome email on computer the QR code should be there and scan it with your phone and install .and reboot the phone or reset network settings see if that helps . Is still no luck please use this direct link to support to help
send a  private message   To CS_Agents click
