08-16-2017 12:06 AM - edited 01-04-2022 02:30 PM
I know this looks like a stupid question, but I can't seem to find the actual answer.
Are 3G plans actually using the 3G network, or are they using LTE but throttled to 3G speeds?
I know they're limited to 2.5Mbps, but is that 2.5Mbps delivered via the 3G or LTE network?
The fact that they're advertised as "3G speeds" makes me think it's the latter, but I'd like some confirmation.
Thanks!
08-16-2017 07:17 PM
@NDesai purely a fluke as I happened to be testing to see if anything had changed yet.... ...for @rob79 in fact!
08-16-2017 07:12 PM - edited 08-16-2017 07:12 PM
@SD08 wrote:Update: According to oracle @NDesai, 3G upload speed will now be capped at ~2.5mbps.
In other words, 3G download and upload speeds will have the same rated maximum.
@SD08 forgot to mention, credit goes to @srlawren who updated us first.
08-16-2017 06:52 PM
08-16-2017 06:31 AM
08-16-2017 12:40 AM
Thank you for the clarification @SD08.
08-16-2017 12:38 AM
Awesome @SD08 - I read through a bunch of forum posts before making this question (because I assumed it had been answered elsewhere) but so much stuff came up I couldn't find an "official" response.
The thread you linked looks "official" enough to satisfy my curiosity! Thanks!
08-16-2017 12:35 AM - edited 08-17-2017 04:42 AM
The 3G plans are delivered over the LTE network, throttled to 2.5 mbps download, 0.400 2.5 mbps upload. While you may temporarily get slightly higher speeds by changing your connection setting to HSPA, that loophole will not last long, as it too will be capped to 2.5 mbps:
EDIT: New maximum upload speed of 2.5 mbps. See update below.
08-16-2017 12:21 AM - edited 08-16-2017 12:24 AM
I believe that these plans are running on the LTE network with speeds throttled to 2.5 Mbps. Your milage may vary, but there have been reports that you can get a little bit more speed out of these plans by setting your phone to connect to regular 4G/HSPA.
iPhone: Settings > Cellular > Cellular Data Options > Switch "Enable LTE" to Off.
Android: Settings > Mobile Networks > Preferred Network Type > Change from LTE/WCDMA/GSM (Auto) to WCDMA/GSM (Auto)
