Where can I find the port out PIN number
George2022
My company provides a mobile plan with Rogers. I want to transfer my Public Mobile number to Rogers.
But it requires me to provide the port out PIN number.
I don't know where to find the PIN. Can anyone help me with this? Much appreciated.
I don't find any customer service phone number on the website.
@dust2dust wrote:
Are you sure you don't want to keep personal and work separate? Also if you've been here a while maybe you'd also want to keep the rewards.
@dust2dust  brings up a good point. Have you considered keeping 2 plans (personal and work). Maybe change your personal to the lowest plan ($15 one 100 outgoing minutes/250MB) and keep it for personal use.
It is great that your work is giving you a cell plan, but usually in these cases, these phones and plans belong to 'your company' and they may have the right to your usage on your plan/phone.
So, just ask certain questions before you get rid of your PM account, so you are comfortable with the choice.
JL9
They only need your account or IMEI, but I would recommend sticking with the account # bc it should be a smooth port, as IMEI sometimes causes headaches.
Meow
Depending on how long you were PM member, consider losing loyalty and other rewards.
No pin is need for porting out; only account and personal details (name, etc.).
dust2dust
I don't think a pin is required. Account # should be sufficient. Then keep this sim in the phone to confirm the transfer.
@George2022   You don't need to provide them the PIN number.  Just provide them the account number, which is on My Account, top right corner
MrSpock
@George2022 hi you should only need your public account number and the name on account remember to leave pm sim in phone to receive port request answer yes
