12-14-2023 02:24 PM
Hi, I'm trying to change credit card info and after entering correct info, have message "sorry, we can't do this at that time, try later" but 48h already. I'm afraid that account will be disconnected. Help ASAP. Pin 1963
12-14-2023 03:49 PM
Please note this is a public forum for people to see all you type. Please delete any information that is private by going back to your message where it shows that circle with the downwards arrow!! You can delete and repost.
12-14-2023 02:27 PM
@Mishamarsha To many failed attempts and you will need to wait one full hour sometimes 24 hours and try again incognito or private mode . Or try from another device even . Can also try the APP .if still no luck you can submit ticket with support to help update the credit card info also
send a private message To CS_Agents
12-14-2023 02:26 PM
HI @Mishamarsha
wait another hour and try again using Incognito/Private/Secret mode on your browser to login and change credit card
if same, please submit a ticket with CS Agent here:
and if you are really worry, get a PM voucher from Shoppers Drug mart and load the voucher using *611
