08-20-2020 08:58 PM - edited 01-05-2022 12:51 PM
08-22-2020 01:37 AM
@computergeek541 wrote:
@RosieR wrote:If your plan includes unlimited data.. then you would not run out of data.
Anyway, you don't need data to send text messages.
Public Mobile does not have plans with unlimited data.
@computergeek541 I just checked and surprise surprise, no PM plan with unlimited data. You are absolutely correct. Thank you, now I know.
08-22-2020 01:13 AM
08-22-2020 01:05 AM
08-20-2020 09:05 PM - edited 08-20-2020 09:09 PM
@Bigmeandean if you're using an iPhone you need to change the settings so you are able to send sms instead of through iMessage
08-20-2020 09:04 PM
Hi
If you are using iMessages specify sms in your settings
You won't need any data for your texts
Your data must be enabled (even though you don't have any left)
08-20-2020 09:03 PM
@Bigmeandean Hi could you please elaborate
08-20-2020 09:00 PM - edited 08-20-2020 09:04 PM
@Bigmeandean You don't need data to send regular text messages unless you mean MMS?
Also try rebooting your phone.
Edit: Clarification even for sending/receiving MMS you don't need plan data only that your data is enabled.
