11-29-2024
04:11 AM
11-29-2024
05:47 AM
computergeek541
What's the best app to show weather on my lock screen? I have an Android phone and I want to see the weather right when I unlock it. What apps do you guys use?
01-06-2025 06:38 AM - edited 01-06-2025 07:05 AM
@ORNGNBLK FYI this will undoubtedly be moved to the “lounge” as it’s not support relate
Not to mention that @devkum1234 has posted this or similar questions on more than one occasion in the past, which also got moved to The Lounge. Not sure what the purpose of these posts is.
01-06-2025 05:17 AM
@devkum1234 FYI this will undoubtedly be moved to the “lounge” as it’s not support related or Public Mobile specific. For future reference.
01-06-2025 05:14 AM
I was just wondering, how do you think using the best lock screen widgets can make Android better? Like, do they actually save time or make life easier? I'm looking for ideas or suggestions about cool widgets that really improve the experience. Share your favorites or tips!
12-12-2024 04:13 AM
Are you on Android 14/15? and depending on your device, you should have customizations!
Motorola has a lot of customization options, or Pixel does too
12-12-2024 02:20 AM
What are the coolest lock screen widgets for Android? I want to make my phone look awesome and show important info like weather, time, and maybe even my calendar. Any suggestions?
12-10-2024 07:09 AM - edited 12-10-2024 07:09 AM
@devkum1234 Assuming you now have the app that you were looking for in a previous question and it offers a widget, something like WeatherCan from Environment Canada for example, on my Android you just long press somewhere on the home screen and then the option to customize with widgets etc. appears.
12-10-2024 06:39 AM
What device are you using, some have the capability, some don’t. Let us know what phone model you have and I’m sure someone can find a solution.
12-10-2024 06:17 AM
I'm new to Android and I can't figure out how to add a weather widget to my lock screen. Someone, please help!
12-06-2024 06:56 AM
@cameronwhite Is this what you mean?
12-06-2024 04:23 AM
Hey everyone, quick question, Is the Glance widget available for Android? I’ve seen it mentioned a few times, but I’m not sure if it’s supported on android devices or how to enable it.
11-29-2024 04:45 AM
I’m exploring ways to get the most out of my Android phone, and I’m curious about the lock screen. It’s more than just a way to secure the phone, right? What are some unique or lesser-known features that can make my lock screen more functional or fun?
11-29-2024 04:31 AM
I use the weather widget on my Samsung S24. It works for me.
