11-29-2023 12:03 AM - last edited on 11-29-2023 02:00 AM by computergeek541
I know I should know this but I can't quite get my head around it....I'll be travelling international (not the US) so I know I can't get a roaming plan with PM. When I'm connected to wifi while out of country, will I be able to receive and respond to texts and emails? Thank you!
11-29-2023 12:48 PM
While travelling to other countries, I have had success using:
WiFi at various locations like hotels, being sure to use a VPN, for email and browsing.
The free Fongo app, which gives you a Canadian phone number, and free calls to Canada. (!)
11-29-2023 09:53 AM - edited 11-29-2023 09:53 AM
SMS text, no; but iMessage to other iPhone's or RCS between Android devices, maybe.
11-29-2023 12:14 AM - edited 11-29-2023 12:14 AM
If you are out of country with Public Mobile you will not be able to text, make or receive calls and use data. You can use your email. However, if you install WhatsApp and your contacts have that app too you will be able to text and make and receive calls when on wifi. If in the US you will need add ons.
11-29-2023 12:12 AM
Hi @VILS,
You will be able to access emails along with any other stuff you normally access online through WiFi. You will not be able to text or makes calls through the Public Mobile network though. If you need to call or text someone, you can do so through other WiFi apps like TextNow, Whatsapp, FB Messenger, etc. Otherwise, if you are not around WiFi, you can buy a local calling card in the country you are visiting.
