Voice and text
Myggirl98
How do I change my plan to voice and text (no data)?
HI  @Myggirl98
there is no voice and text only plan
However, the closest you can get is the $15 plan with 100 outbound minutes and text and 250Mb data or $25 plan with unlimited calls and text and 1GB of data
if you just don't want to use the data, disable the mobile data on your phone.  But if you worry about overuse the data, on need to worry, PM is prepaid provider, there is no overage.  Once data are all used, it stops working
JRod
@Myggirl98
Hello! I believe all of the plans PM offers have data. The $15 plan is the cheapest and gives you 250MB of Data. If you login on your account, go to subscription and add-ons, and then change subscription. It will then show you all the available plans and you can choose something to your liking.
Do know if you change your plan immediately you will be charged the full amount and not be reimbursed if you have time remaining on your current plan. This is why many suggest changing on renewal if you can wait.
Sorry, but there are no plans available that don't include data.  Data can be disabled in the device's settings.
