05-18-2023 02:40 PM
Hello I'm leaving to India. I would like to know the options.
05-18-2023 05:52 PM
The search bar at the top of the page is there for you to educate yourself and look for answers. It is very helpful to read other posts related to your issue.
Enjoy your trip.
05-18-2023 02:49 PM
@Divyas unfortunately, you won't be able to receive calls and text 😞
There used to be voice calls solution to redirect calls to VoIP app but Conditional forward has been broken
So, you will have to rely on VoIP solely (together with local data sim). Setup one yourself ahead of the trip and give the number to your friends.
And those 2FA from banks, make sure you change to Authenticator app or email as you won't be getting text when you are there
05-18-2023 02:47 PM
I want to receive calls and text messages in India. I got my answer. Thank you.
05-18-2023 02:43 PM
what option are you looking for?
for mobile option, PM does not provide any roaming service there, so, you will have to rely on local data sim card there. Maybe use VoIP app TextNow to make free calls to Canada and receive calls
If you meant actually "vacation alert" to those who call you, you can try to record an extended leave message on your Voicemail
