05-21-2024 12:34 PM - last edited on 05-21-2024 04:53 PM by computergeek541
May 19th tried to port the number over from Koodo and it didn’t work.
I have reception on Koodo and can get incoming calls but cannot receive text msgs. My phone doesn’t show the eSIM and I cannot add it manually.
I did get the confirmation txt from Koodo and phone was turned on and off in attempt to reset.
05-21-2024 12:44 PM
Tried the QR but got a msg saying eSIM activation failed.
05-21-2024 12:37 PM
HI @Sfour77
your phone doens't show the esim, PM esim?
if you don't see PM esim on the sim screen, it is a sim problem and unrelated with porting
check the Welcome email from PM, it should have a QR code for esim, scan to install
if you don't have such QR code or cannot install, please ask support agent to help by direct messag:
